Aller au contenu principal
2006 Kia Spectra Battery Replacement
Ce dont vous avez besoin
  1. 2006 Kia Spectra Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn the car off.
  2. 2006 Kia Spectra Battery Replacement: étape 2, image 1 de 2 2006 Kia Spectra Battery Replacement: étape 2, image 2 de 2
    • Locate the hood release lever near the lower left side of the steering wheel. Pop the hood by lifting up on the release lever.
  3. 2006 Kia Spectra Battery Replacement: étape 3, image 1 de 3 2006 Kia Spectra Battery Replacement: étape 3, image 2 de 3 2006 Kia Spectra Battery Replacement: étape 3, image 3 de 3
    • Remove the positive (red circle) cable from the battery using the wrench to loosen the nut and bolt.
    • Then, remove the negative (orange circle) cable battery, using the wrench to loosen the nut and bolt.
  4. 2006 Kia Spectra Battery Replacement: étape 4, image 1 de 2 2006 Kia Spectra Battery Replacement: étape 4, image 2 de 2
    • Take the battery out, lifting the battery.
    • The battery will be heavy.
  5. 2006 Kia Spectra Battery Replacement: étape 5, image 1 de 1
    • Clean the new battery with a rag to make sure it is ready to go.
  6. 2006 Kia Spectra Battery Replacement: étape 6, image 1 de 3 2006 Kia Spectra Battery Replacement: étape 6, image 2 de 3 2006 Kia Spectra Battery Replacement: étape 6, image 3 de 3
    • Place the new battery in the base where the battery goes.
  7. 2006 Kia Spectra Battery Replacement: étape 7, image 1 de 2 2006 Kia Spectra Battery Replacement: étape 7, image 2 de 2
    • Attach the positive (red cirlce) cable to the battery by screwing on the nut and bolt with the wrench.
  8. 2006 Kia Spectra Battery Replacement: étape 8, image 1 de 3 2006 Kia Spectra Battery Replacement: étape 8, image 2 de 3 2006 Kia Spectra Battery Replacement: étape 8, image 3 de 3
    • Then, attach the negative (red arrow) cable to the battery by screwing on the nut and bolt with the wench.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 54
Total : 4,678
