Introduction
This guide demonstrates how to change a front brake master cylinder on a 2006 Suzuki GSX-R600. This repair might be needed if your brake lever is touching your handlebar when depressed. This is not the easiest process, but by following this guide, you should be able to do it on your own and save some money! Check the tools section for required tools. Purchase a new master cylinder if yours is damaged and/or old.
You'll need a bit of patience, as this repair can take some time. Be patient and follow the steps carefully.
Before beginning, make sure your bike is off and fully cool, then throw on a pair of nitrile gloves.
Ce dont vous avez besoin
Use a 3/32 inch Allen key to remove the bolt securing the brake lever.
Your front brake is now working as intended!
