Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement
    1. 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Access the Engine Bay: étape 1, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Access the Engine Bay: étape 1, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Access the Engine Bay: étape 1, image 3 de 3
      • Find the bonnet latch inside the cabin and pull to release the bonnet (typically in the driver/passenger footwell).
      • Reach under the bonnet to find the second lever that fully opens the bonnet, giving access to the engine bay.
      • On the M271 Evo 1.8l Turbo engine, the air intake hose is on the right side of the engine bay
      Demander à FixBot
      Ajouter un commentaire
    2. 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Remove Rear Hose Connector: étape 2, image 1 de 2 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Remove Rear Hose Connector: étape 2, image 2 de 2
      • Find the plastic end of the intake hose and firmly pull until released
      Demander à FixBot
    3. 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Remove Front Hose Connector: étape 3, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Remove Front Hose Connector: étape 3, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Air Intake Hose for M271 Engine Replacement, Remove Front Hose Connector: étape 3, image 3 de 3
      • Find the plastic latch holding the scoop of the intake hose
      • Using a pry tool or similar, press down on the latch until it releases the scoop
      • Firmly pull the scoop away from the plastic housing and remove the old hose from the engine bay. You may need to rotate the scoop to unhook a latch on the underside of the plastic housing.
      Demander à FixBot
Phillip Andrews
Membre depuis le 03/16/20
241 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 56
30 derniers jours : 233
Total : 381
