Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement
Ce dont vous avez besoin
    1. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement, Engine Air Filter: étape 1, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement, Engine Air Filter: étape 1, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement, Engine Air Filter: étape 1, image 3 de 3
      • Open the driver's side door and locate the red hood-release handle on the lower dash panel, just left of the brake pedal.
      • Pull the handle towards you until the hood pops.
      • At the front of the vehicle, release the secondary latch above the grille area, and lift the hood.
      Demander à FixBot
      Ajouter un commentaire
    2. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 2, image 1 de 2 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 2, image 2 de 2
      • Pull straight up on the engine cover to release it from the rubber grommets.
      • Lift at the front corners to remove the front panel.
      • Remove the engine cover and set it aside.
      • Identify the screws shown in the second image.
      Demander à FixBot
    3. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 3, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 3, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 3, image 3 de 3
      • Attach an E10 socket to a ratchet and remove the bolts securing the bracket along the top edge of the engine cover.
      • Take care not to drop the bolts, as you will need them to reinstall the bracket.
      • You may need some WD-40 to loosen them.
      Demander à FixBot
    4. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 4, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 4, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 4, image 3 de 3
      • Push the locking tab on the sensor to the right until it fully extends.
      • Disconnect and lift the sensor off the intake hose.
      • Set it aside on the right, resting on top of the hose, and keep the tip clean.
      • Do not get the tip dirty!
      Demander à FixBot
    5. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 5, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 5, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 5, image 3 de 3
      • Use a flathead screwdriver to loosen the intake tube clamp until it releases.
      • You'll hear and see it snap apart, and you can reuse it.
      Demander à FixBot
    6. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 6, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 6, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 6, image 3 de 3
      • Remove the air filter intake tube.
      • Lift the entire filter straight up out of the engine block and place it sideways in your workspace.
      Demander à FixBot
    7. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 7, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 7, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 7, image 3 de 3
      • Loosen the three perimeter Torx T-25 screws securing the air filter lid.
      • Leave the screws in place, as they are spring-loaded. Just loosen them completely without pulling them out.
      Demander à FixBot
    8. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 8, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 8, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 8, image 3 de 3
      • Use the bottom hinge to open the engine air filter from the top, flipping it open like a book.
      • Position the part with the filter facing upright.
      Demander à FixBot
    9. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 9, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 9, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 9, image 3 de 3
      • Lift the old filter straight up and out, keeping it level to prevent debris from falling into your workspace.
      • Clean out any debris with a broom or other cleaning tool.
      • Ensure the male and female connectors on the new filter and the housing match.
      Demander à FixBot
    10. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 10, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 10, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 10, image 3 de 3
      • Place the new engine air filter back into the housing.
      • Ensure the new filter is seated with the rubber seal flat all around.
      • Close the lid evenly and reinstall all of the lid screws (avoid overtightening plastic).
      • Slide the intake tube fully onto the snout and align the E-10 bolt mounts.
      Demander à FixBot
    11. 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 11, image 1 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 11, image 2 de 3 2007-2014 Mercedes-Benz C-Class (W204) Engine Air Filter Replacement: étape 11, image 3 de 3
      • Reattach the filter to the bracket before moving on!
      • Reassemble the lid, clamp, hoses, and bracket. Use flat-tipped pliers to squeeze the clamp together until you hear a click indicating a secure connection.
      • Finally, reconnect your (MAF) sensor to the hose.
      • FINISHED! Double-check that everything is securely attached. Start your car and listen for any unusual sounds.
      Demander à FixBot
Reinstall the airbox lid, tighten the clamp, reconnect the breather hoses, and refit the engine cover. Start the engine and listen for air leaks; if you hear a whistle, reseat the lid and retighten the clamp/screws.
Cameron Modock
Membre depuis le 10/05/25
193 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-1, Watkins Fall 2025 Membre de l'équipe Austin Community College, Team 1-1, Watkins Fall 2025
AUSTINCC-WATKINS-F25S1G1
1 membre
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 101
30 derniers jours : 372
Total : 2,249
