Aller au contenu principal
2007-2012 Acura RDX Engine Air Filter Replacement
Ce dont vous avez besoin
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: étape 1, image 1 de 1
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: étape 2, image 1 de 1
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: étape 3, image 1 de 1
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: étape 4, image 1 de 1
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: étape 5, image 1 de 2 2007-2012 Acura RDX Engine Air Filter Replacement: étape 5, image 2 de 2
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
One the task is done, close the hood and you are good to drive!
Andrew Graham
Membre depuis le 03/23/21
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G6, Riel Spring 2021 Membre de l'équipe UMass Dartmouth, Team S2-G6, Riel Spring 2021
UMASSD-RIEL-S21S2G6
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 86
Total : 846
