Ce dont vous avez besoin
Vidéo d'introduction
Loosen the lugnuts. Use a breaker bar if necessary.
Lift the car. Secure the car with safety stands and tire chucks/blocks.
Remove the wheel and set aside.
Pull on the caliper to compress the piston, so it will slide off when you remove it.
Loosen the caliper slide bolts.
Use a bungee cord or S hook to hang the caliper from the shocks, to keep weight off the brake line.
Slide the pads out.
Remove 2 17mm bolts that hold the caliper bracket on and remove the remaining caliper hardware.
Remove the Rotor
If it is rusted on, you can use 2 small threaded bolts to push into the small holes and against the hub to remove the rotor. Or if you are replacing the rotor, you can hit it with a hammer to loosen it up.
Put new rotor on backwards and clean off oil it ships with with brake parts cleaner, wiping any excess off with a paper towel. Reverse the rotor and repeat cleaning on the correct side.
Clean off brake caliper hardware to reuse.
Coat bottom edge of caliper tins with a small amount of anti-seize grease. Coat caliper bracket with grease where the tins sit.
Remove caliper slide bolts and apply grease if it is binding up or you can feel it grinding when you twist and pull it out. Apply grease to the flat spots liberally. Replace by twisting the bolt back in to coat the grease.
Install the top caliper bracket bolt first (17mm head). This will make the bottom one easier to line up.
Put a tiny amount of grease on the ears of the brake pad.
Put new brake pads in. Fit bottom ear in first to help line up the top. Attach spring hardware to the brake pads.
Compress the caliper piston with a C clamp and the old brake pad so it will fit the new brake pads.
Fit caliper piston onto rotor and reinstall caliper slide bolts to the bracket. Torque the caliper mounting bracket bolts to 79 ft/lbs. Don't forget to remove the bungee cord or S hook you used to hang the caliper piston. Make sure the rotor surface is clean.
Put the wheel back on.
Snug up the lug nuts in a star pattern with a ratchet wrench or lug wrench.
Lower car and Torque lugnuts to 76 ft/lbs in a star pattern. If you don't have a torque wrench, hand tighten as much as possible with the lug wrench.
Get in the car and pump the break pedal about a quarter of the way 15-20 times to return pressure to the caliper piston. You should feel the pedal firm up.
Don't forget to remove the tire chucks/blocks.
Repeat for other side.
