Aller au contenu principal
2007-2011 Toyota Camry Headlight Bulb Replacement
  1. 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: étape 1, image 1 de 2 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: étape 1, image 2 de 2
    • Pop up the hood of the car.
  2. 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 2, image 1 de 2 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 2, image 2 de 2
    • Locate the headlight bulb on the inside of the hood and hold onto the bulb.
    • The other headlight bulb is in the same area on the other side of the car.
  3. 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 3, image 1 de 2 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 3, image 2 de 2
    • Turn counterclockwise (1/4 of a turn) to remove the bulb and its attached plug from the socket.
    • This step is applied for both headlight bulbs.
  4. 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 4, image 1 de 2 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 4, image 2 de 2
    • Hold onto the bulb with one hand while holding down the clip at the bottom of the plug to remove the bulb.
  5. 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 5, image 1 de 2 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 5, image 2 de 2
    • Remove the new bulb from its package.
    • Make sure to not touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Wipe the bulb with a paper towel if contact was made.
  6. 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 6, image 1 de 2 2007-2011 Toyota Camry Headlight Bulb Replacement: étape 6, image 2 de 2
    • Place the bulb back into the plug and press down until it click into place.
    • The bulb only goes in one way. Make sure the plug and the bulb are facing the same direction.
3 autres ont terminé cette réparation.
Phuc Nguyen
Membre depuis le 03/31/20
214 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 56
30 derniers jours : 247
Total : 13,257
