Aller au contenu principal
2007-2011 Toyota Yaris Drip Rail Replacement
Ce dont vous avez besoin
  1. 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: étape 1, image 1 de 3 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: étape 1, image 2 de 3 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: étape 1, image 3 de 3
    • Peel back the old molding from where it is beginning to come off until you reach the end of the rail.
  2. 2007-2011 Toyota Yaris Drip Rail Replacement: étape 2, image 1 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 2, image 2 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Heavy-Duty Spudger
    J'achète
    • Use a heavy duty spudger to disconnect the end of the drip rail.
    • It may be connected at the end pretty tightly so it could take some work to remove.
    • Completely remove the piece from the end.
  3. 2007-2011 Toyota Yaris Drip Rail Replacement: étape 3, image 1 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 3, image 2 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 3, image 3 de 3
    • Take a rag and clean out any dirt and debris that built up under the old molding.
  4. 2007-2011 Toyota Yaris Drip Rail Replacement: étape 4, image 1 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 4, image 2 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 4, image 3 de 3
    • Slide the end of the new piece into the designated spot and press firmly to ensure it's connected securely.
    • Lightly tug at it to make it is secure and won't come off.
    • Do the same to the opposite end of the drip rail.
    • The molding for the left and right drip rails are different parts.
  5. 2007-2011 Toyota Yaris Drip Rail Replacement: étape 5, image 1 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 5, image 2 de 3 2007-2011 Toyota Yaris Drip Rail Replacement: étape 5, image 3 de 3
    • Firmly press the drip rail into its place starting at one end and moving down the car.
    • Check to make sure the new drip rail is thoroughly sealed to the car.
Isabel Sagheb
Membre depuis le 04/19/23
121 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-2, Morris Spring 2023 Membre de l'équipe UC Davis, Team 2-2, Morris Spring 2023
UCD-MORRIS-S23S2G2
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 70
Total : 814
