Aller au contenu principal
2007 Honda CR-V Brake Light Replacement
Ce dont vous avez besoin
  1. 2007 Honda CR-V Brake Light Replacement, Brake Light: étape 1, image 1 de 3 2007 Honda CR-V Brake Light Replacement, Brake Light: étape 1, image 2 de 3 2007 Honda CR-V Brake Light Replacement, Brake Light: étape 1, image 3 de 3
    • Grab the handle in the middle of the trunk.
    • Use the handle to pull the trunk open.
  2. 2007 Honda CR-V Brake Light Replacement: étape 2, image 1 de 2 2007 Honda CR-V Brake Light Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the top and bottom screws.
  3. 2007 Honda CR-V Brake Light Replacement: étape 3, image 1 de 2 2007 Honda CR-V Brake Light Replacement: étape 3, image 2 de 2
    • Pull back the tail light cover.
    • Hold it up; there are cords connected to the car inside.
  4. 2007 Honda CR-V Brake Light Replacement: étape 4, image 1 de 3 2007 Honda CR-V Brake Light Replacement: étape 4, image 2 de 3 2007 Honda CR-V Brake Light Replacement: étape 4, image 3 de 3
    • Untwist the faulty bulb counter-clockwise.
    • Pull the bulb out of the socket.
  5. 2007 Honda CR-V Brake Light Replacement: étape 5, image 1 de 2 2007 Honda CR-V Brake Light Replacement: étape 5, image 2 de 2
    • Disconnect the bulb from the cord by popping it off.
  6. 2007 Honda CR-V Brake Light Replacement: étape 6, image 1 de 2 2007 Honda CR-V Brake Light Replacement: étape 6, image 2 de 2
    • Pop in the Sylvania LongLife Mini Bulb 7443LL.
  7. 2007 Honda CR-V Brake Light Replacement: étape 7, image 1 de 3 2007 Honda CR-V Brake Light Replacement: étape 7, image 2 de 3 2007 Honda CR-V Brake Light Replacement: étape 7, image 3 de 3
    • Insert the bulb into the socket.
    • Twist the bulb in clockwise.
  8. 2007 Honda CR-V Brake Light Replacement: étape 8, image 1 de 2 2007 Honda CR-V Brake Light Replacement: étape 8, image 2 de 2
    • Set the tail light cover back to the default position over the screw holes.
  9. 2007 Honda CR-V Brake Light Replacement: étape 9, image 1 de 2 2007 Honda CR-V Brake Light Replacement: étape 9, image 2 de 2
    • Use a Phillips #00 screwdriver to screw in the top and bottom screws.
Ligne d'arrivée
Dillon Laney
Membre depuis le 02/21/23
169 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 30
30 derniers jours : 132
Total : 1,077
