Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2007 Honda Civic Reverse Lights Replacement
Ce dont vous avez besoin
  1. 2007 Honda Civic Reverse Lights Replacement, Reverse Lights: étape 1, image 1 de 2 2007 Honda Civic Reverse Lights Replacement, Reverse Lights: étape 1, image 2 de 2
    • Open the rear trunk and locate the reverse lights.
  2. 2007 Honda Civic Reverse Lights Replacement: étape 2, image 1 de 2 2007 Honda Civic Reverse Lights Replacement: étape 2, image 2 de 2
    • Insert a flathead screwdriver into the fastener.
    • Rotate the screwdriver counterclockwise until the fastener loosens.
    • Carefully remove the fastener.
  3. 2007 Honda Civic Reverse Lights Replacement: étape 3, image 1 de 2 2007 Honda Civic Reverse Lights Replacement: étape 3, image 2 de 2
    • Pull the lining away from the lights.
    • Carefully grasp the reverse light socket.
    • Make sure it is the correct socket; do not remove the other sockets, as those are your brake lights and turn signal lights.
    • Twist left to release the socket.
    • Slowly pull back from the socket to have access to the light socket.
  4. 2007 Honda Civic Reverse Lights Replacement: étape 4, image 1 de 3 2007 Honda Civic Reverse Lights Replacement: étape 4, image 2 de 3 2007 Honda Civic Reverse Lights Replacement: étape 4, image 3 de 3
    • Use a paper towel or rag to pull the socket back carefully and remove the light.
    • Do this for both sides when replacing the reverse lights.
  5. 2007 Honda Civic Reverse Lights Replacement: étape 5, image 1 de 1
    • Get your new reverse lights and install into each socket.
    • When installing, instead of pulling, push into the sockets and ensure they are locked in place.
  6. 2007 Honda Civic Reverse Lights Replacement: étape 6, image 1 de 1
    • Twist to the right and ensure it is locked into place.
Ligne d'arrivée
Andrew Rodriguez
Membre depuis le 10/21/24
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-74, Harris Fall 2024 Membre de l'équipe CSU Los Angeles, Team 4-74, Harris Fall 2024
CSULA-HARRIS-F24S4G74
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 339
