Aller au contenu principal
2008 - 2020 Dodge Caravan Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement, Headlight bulb: étape 1, image 1 de 1
    • Park the car on a level surface.
    • Turn off the car and put on the emergency break for extra safety.
  2. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 2, image 1 de 2 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 2, image 2 de 2
    • Lift the hood release on the drivers side seat, near the foot pedals.
    • Open the hood latch and lift the hood up until it stays open on its own.
    • The headlight socket is located along inside edge of the hood.
  3. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 3, image 1 de 3 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 3, image 2 de 3 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 3, image 3 de 3
    • At the rear of the headlight assembly, rotate the bulb in a counterclockwise direction to detach it from the socket.
    • Release the clips on both sides and take it out from the wiring harness.
    • Insert the new bulb into the harness. You will know it is complete when you feel the clips attaching.
    • Don't touch the bulb with your bare hands. The oils and salt from your hands will reduce the life of the bulb and possibly damage it.
  4. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 4, image 1 de 1
    • Align the tabs on the socket with the opening on the back to reinstall it.
    • Turn the socket clockwise to secure it.
  5. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 5, image 1 de 2 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: étape 5, image 2 de 2
    • Close the hood.
    • Test out your new lights.
    • To view the lights better, test them out at night.
To replace other lights, follow the same guide.
2 autres ont terminé cette réparation.
Abdel Rahman Abusamaha
Membre depuis le 09/04/23
151 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-2, O'Regan Fall 2023 Membre de l'équipe York University, Team 1-2, O'Regan Fall 2023
YORK-O'REGAN-F23S1G2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 90
Total : 598
