Introduction
This guide will show you how to replace headlight bulbs on your fifth generation Dodge Caravans which cover the years 2008-2020. It will walk you through removing the old bulbs and installing new headlights bulbs for your van. Over time, old lights tend to emit less light through the headlight which makes it harder to see at night. It's advisable to replace both headlights even if only one is out. The other light is likely to go out soon, and replacing both now can help avoid additional repairs.
Some things to consider while following this guide:
- Make sure you wear gloves to avoid getting oils and salts from your hands on the new bulbs. The oils can create hot spots on the bulb which will reduce the life of the bulb and or even shatter.
- Make sure you have the correct bulb lights for this make and model of van.
- Make sure the car is off and has cooled off if you have used it recently. You will be working under the hood.
- Park the car and use the emergency break for extra safety.
Ce dont vous avez besoin
Park the car on a level surface.
Turn off the car and put on the emergency break for extra safety.
To replace other lights, follow the same guide.
2 autres ont terminé cette réparation.
