Aller au contenu principal
2008-2012 Honda Accord ATF replacement - Every 80k Miles
Ce dont vous avez besoin
    • Caution: Injury may result if this procedure is not followed properly. Be sure to follow each step carefully and follow all warnings.
    • Every 30k miles, do a plain vanilla drain and fill. The steps in this guide are not for a vanilla drain and fill.
    • Every 80k miles, do a full flush as shown in this guide.
    • V6 Engines: Use this video. Loosen 11/16" bolt with "ATF" printed on it. Use a 10" socket extension. This allows air into the transmission as the fluid drains out later.
    • Remove fill plug washer, which may be just sitting on the transmission case. Do not drop the washer into the transmission or your car must be towed!
    • V4 and I4 Engines: Use this video. Remove the Transmission Fluid Dipstick. This allows air into the transmission as the fluid drains out later.
    • Caution! Fluid will be hot. Loosen drain plug a little and let fluid come out slowly into a bucket.
    • Open drain plug with a 3/8" socket drive
    • When mostly drained, fluid flow will decrease to a dribble. Wait until fluid has drained to unscrew the drain plug all the way and remove it.
    • Wipe metal filings and any fluid off the drain plug. Replace the drain plug and tighten to hand-tight.
    • Replace drain plug and tighten to finger tight.
    • Fill transmission from fill plug (or dipstick). Use 2.5 quarts of Honda DW-1 Automatic Transmission Fluid. Use a funnel and pour carefully to not spill fluid.
    • Replace fill plug (or dipstick).
    • Wait 15 minutes, then check transmission fluid level. This allows fluid to enter all the corners of the transmission. If needed, add last 0.5 quarts of fluid.
    • Drive the car and make sure to reach all gears. This should be about freeway speed.
    • Loosen the fill plug (or dipstick)
    • Drain the fluid following previous instructions. CAUTION: HOT FLUID.
    • Replace drain plug following previous instructions.
    • Refill transmission with a funnel and 2.5 quarts of the same fluid as before.
    • Replace fill plug (or dipstick). Wait 15 minutes. Check transmission fluid level. Add last 0.5 quarts if needed.
    • Loosen the fill plug (or dipstick).
    • Place a new crush washer on drain plug. Tighten the drain plug using a Torque Wrench to 36 ft-lb of torque.
    • Refill with a funnel and 3 quarts of the same fluid as before.
    • Wait 15 minutes.
    • Check transmission fluid level. Top off transmission fluid if needed.
    • One day after the flush, inspect the transmission for signs of fluid leaking.
    • Check transmission fluid level. Add transmission fluid if the fluid level is a little low, using a funnel. When checking fluid level, engine and transmission should be up to normal temperature, which is reached after about 5 minutes of driving
    • Two days after the flush, inspect transmission again for signs of fluid leaking.
Summary:
Drain, add 2.5 quarts, run through all gears.
Drain, replace crush washer, add 3 quarts.
(Top off fluid the next day if needed.)
9 autres ont terminé cette réparation.
ndsol
Membre depuis le 11/11/10
2 890 Réputation
16 tutoriels rédigés
5 commentaires
At what step would you replace the filter?
Mark Schouten - Réponse
Where are they getting their information? Honda does not follow this. https://techinfo.honda.com/rjanisis/pubs...
Charles - Réponse
Stop calling this a flush. It’s a simple drain and fill as it should be. A flush infers a machine pumping the fluid in and out, which will destroy a Honda transmission.
Greg Cox - Réponse
Ok, I updated the title.
ndsol -
excellence instruction. Thank you so much….
Victor Hong - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 124
30 derniers jours : 575
Total : 94,144
