Aller au contenu principal
2008-2012 Honda Accord Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2008-2012 Honda Accord Headlight Bulb Replacement, Headlight Bulb: étape 1, image 1 de 1
    • (Right Side Headlight)
    • Turn the wheel all the way inward to have enough clearance.
    • Turn the vehicle fully off before proceeding to the next step.
  2. 2008-2012 Honda Accord Headlight Bulb Replacement: étape 2, image 1 de 3 2008-2012 Honda Accord Headlight Bulb Replacement: étape 2, image 2 de 3 2008-2012 Honda Accord Headlight Bulb Replacement: étape 2, image 3 de 3
    • Locate the inner fender's retainer clips.
    • Using a flat-head screwdriver, pry out the retainer clips.
  3. 2008-2012 Honda Accord Headlight Bulb Replacement: étape 3, image 1 de 1
    • Pry back the inner fender liner to gain access to the headlight bulb.
    • An object may be needed to keep the fender liner pulled back
  4. 2008-2012 Honda Accord Headlight Bulb Replacement: étape 4, image 1 de 3 2008-2012 Honda Accord Headlight Bulb Replacement: étape 4, image 2 de 3 2008-2012 Honda Accord Headlight Bulb Replacement: étape 4, image 3 de 3
    • Locate the headlight bulb, and turn the item clockwise so that it points towards the engine.
    • For the left bulb, turn the item counter clock-wise
  5. 2008-2012 Honda Accord Headlight Bulb Replacement: étape 5, image 1 de 2 2008-2012 Honda Accord Headlight Bulb Replacement: étape 5, image 2 de 2
    • Pull out the headlight bulb from its socket.
    • Be careful while pulling the bulb out, you might damage the bulb or its connected cable.
  6. 2008-2012 Honda Accord Headlight Bulb Replacement: étape 6, image 1 de 3 2008-2012 Honda Accord Headlight Bulb Replacement: étape 6, image 2 de 3 2008-2012 Honda Accord Headlight Bulb Replacement: étape 6, image 3 de 3
    • For a more visible view of this step since the space is small and cluttered. -Credit for these 3 pictures: @PrecisionLED
    • To disconnect the bulb, pinch the top of the white block to release it from the bulb
    • When installing a new bulb, be careful while handling the bulb to not smudge or damage the bulb.
Carson Nguyen
Membre depuis le 10/23/23
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-16, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 5-16, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G16
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 85
30 derniers jours : 370
Total : 2,531
