Aller au contenu principal
2008-2010 Audi A3 Sportback License Plate Lights Replacement
Ce dont vous avez besoin
  1. 2008-2010 Audi A3 Sportback License Plate Lights Replacement, License Plate Lights: étape 1, image 1 de 1
    • The red arrows point to the relative location of the license plate lights (under overhang of hatch door where license plate is).
  2. 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 2, image 1 de 1
    • Open the hatchback and hold it in place so that you can easily reach the lights that illuminate the license plate. You may need to have another person hold the hatchback steady for you.
  3. 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 3, image 1 de 2 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 3, image 2 de 2
    • Using a small screwdriver, loosen and remove the screw that is holding the license plate light in place with a Phillips #1 screwdriver.
  4. 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 4, image 1 de 3 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 4, image 2 de 3 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 4, image 3 de 3
    • Once the screw is removed, wedge the end of a spudger or flathead screwdriver between the light and the black plastic.
    • Gently pop the light out.
  5. 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 5, image 1 de 2 2008-2010 Audi A3 Sportback License Plate Lights Replacement: étape 5, image 2 de 2
    • Use one hand to hold the light steady. Place the thumb and the index finger of the other hand on the metal ends of the light. Gently pull the light away from the metal frame.
    • Do not touch the glass part of the light with your fingers.
4 autres ont terminé cette réparation.
Tania Fulbright
Membre depuis le 10/30/19
481 Réputation
3 tutoriels rédigés
Équipe
University of Memphis, Team S4-G4, Kim Fall 2019 Membre de l'équipe University of Memphis, Team S4-G4, Kim Fall 2019
UM-KIM-F19S4G4
3 membres
5 tutoriels rédigés
Un commentaire
wow thanks!!! but have you tried just turning it off and on?
lle - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 67
Total : 3,553
