Aller au contenu principal
2008 Ford F-150 Air Filter
Ce dont vous avez besoin
  1. 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: étape 1, image 1 de 2 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: étape 1, image 2 de 2
    • Turn the engine off.
    • Pull the lever to release the hood.
    • Open the hood.
  2. 2008 Ford F-150 Air Filter: étape 2, image 1 de 3 2008 Ford F-150 Air Filter: étape 2, image 2 de 3 2008 Ford F-150 Air Filter: étape 2, image 3 de 3
    • Find the filter housing unit.
    • Pull the leaver to release the clamp.
    • Move the housing unit out of the way to free the filter.
  3. 2008 Ford F-150 Air Filter: étape 3, image 1 de 2 2008 Ford F-150 Air Filter: étape 3, image 2 de 2
    • Remove the filter by pulling it straight out.
    • If you are replacing the filter completely, skip to step 7 after completing this step.
  4. 2008 Ford F-150 Air Filter: étape 4, image 1 de 1
    • Hit the filter with hand, or on the ground, to remove any large particles that are stuck in the filter.
  5. 2008 Ford F-150 Air Filter: étape 5, image 1 de 2 2008 Ford F-150 Air Filter: étape 5, image 2 de 2
    • Get a hose with running water.
    • Guide the hose inside the filter, pushing out all the smaller particles.
    • This step will take about 15 minutes, go slow.
  6. 2008 Ford F-150 Air Filter: étape 6, image 1 de 2 2008 Ford F-150 Air Filter: étape 6, image 2 de 2
    • Place the wet filter outside for it to air dry.
    • Placing the filter in direct sunlight will allow the drying to happen quicker.
  7. 2008 Ford F-150 Air Filter: étape 7, image 1 de 1
    • When the filter is completely dry, replace the filter in the housing unit.
  8. 2008 Ford F-150 Air Filter: étape 8, image 1 de 3 2008 Ford F-150 Air Filter: étape 8, image 2 de 3 2008 Ford F-150 Air Filter: étape 8, image 3 de 3
    • Resemble the housing unit and close the hood.
To install a new air filter follow steps 1-3 to remove the old filter and steps 7-8 to install the new air filter
Brennan DuBose
Membre depuis le 09/19/22
157 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 1-3, Cameron Fall 2022 Membre de l'équipe University of Memphis, Team 1-3, Cameron Fall 2022
UM-CAMERON-F22S1G3
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 306
