Aller au contenu principal
2008 Honda Fit Inner Door Grip Replacement
  1. 2008 Honda Fit Inner Door Grip Replacement, Inner Door Grip: étape 1, image 1 de 1
    • Park the car on a level surface and engage the parking brake.
  2. 2008 Honda Fit Inner Door Grip Replacement: étape 2, image 1 de 2 2008 Honda Fit Inner Door Grip Replacement: étape 2, image 2 de 2
    • Open the door to access the interior door panel. Remove any dirt or tape from the door handle.
    • Remove the taped or broken inner door handle from the inner door panel of the car.
  3. 2008 Honda Fit Inner Door Grip Replacement: étape 3, image 1 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 3, image 2 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 3, image 3 de 3
    • Retrieve the door grip and hook the door grip to the panel by the hook that is attached to the door panel.
  4. 2008 Honda Fit Inner Door Grip Replacement: étape 4, image 1 de 2 2008 Honda Fit Inner Door Grip Replacement: étape 4, image 2 de 2
    • Once the door grip is hooked to the door panel, the door grip will hang.
  5. 2008 Honda Fit Inner Door Grip Replacement: étape 5, image 1 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 5, image 2 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 5, image 3 de 3
    • Starting with the right side, adjust the door grip to the claw attached to the door panel's right side.
    • Push the door grip gently.
  6. 2008 Honda Fit Inner Door Grip Replacement: étape 6, image 1 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 6, image 2 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 6, image 3 de 3
    • Push the door grip to the claw attached to the door panel to lock the door grip so it attaches.
  7. 2008 Honda Fit Inner Door Grip Replacement: étape 7, image 1 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 7, image 2 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 7, image 3 de 3
    • Insert the door grip into the center of the door panel that has two holes.
    • Make sure the centerpiece of the door grip is aligned with the center holes of the door panel for it to attach properly.
  8. 2008 Honda Fit Inner Door Grip Replacement: étape 8, image 1 de 2 2008 Honda Fit Inner Door Grip Replacement: étape 8, image 2 de 2
    • Push the door grip to the claws on the top center of the door panel so it attaches.
  9. 2008 Honda Fit Inner Door Grip Replacement: étape 9, image 1 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 9, image 2 de 3 2008 Honda Fit Inner Door Grip Replacement: étape 9, image 3 de 3
    • Finally, press the left side of the door grip to the far left of the door panel to align with the door clips so that it holds the left side balancing the right.
  10. 2008 Honda Fit Inner Door Grip Replacement: étape 10, image 1 de 1
    • Once each side of the door grip is attached to the door panel the inner door grip/handle is fixed.
Ligne d'arrivée
Shambhavi Bhandari
Membre depuis le 04/20/23
208 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-7, Briggs Spring 2023 Membre de l'équipe CSU Los Angeles, Team 2-7, Briggs Spring 2023
CSULA-BRIGGS-S23S2G7
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 98
Total : 922
