Aller au contenu principal
2008 Honda Pilot Tail Light Assembly Replacement
Ce dont vous avez besoin
  1. 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: étape 1, image 1 de 2 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: étape 1, image 2 de 2
    • Open the vehicle's trunk to see the two bolts holding the assembly to the body.
    • Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
    • Save the bolts! They will be needed for installing the new assembly.
  2. 2008 Honda Pilot Tail Light Assembly Replacement: étape 2, image 1 de 2 2008 Honda Pilot Tail Light Assembly Replacement: étape 2, image 2 de 2
    • Place both hands on the assembly and pull it away from the vehicle.
    • There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
    • If the clips won't disengage try using a rocking motion while pulling on the assembly.
  3. 2008 Honda Pilot Tail Light Assembly Replacement: étape 3, image 1 de 3 2008 Honda Pilot Tail Light Assembly Replacement: étape 3, image 2 de 3 2008 Honda Pilot Tail Light Assembly Replacement: étape 3, image 3 de 3
    • Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
    • Pull the light sockets out of the assembly.
  4. 2008 Honda Pilot Tail Light Assembly Replacement: étape 4, image 1 de 3 2008 Honda Pilot Tail Light Assembly Replacement: étape 4, image 2 de 3 2008 Honda Pilot Tail Light Assembly Replacement: étape 4, image 3 de 3
    • Set the old assembly aside.
    • Take the new assembly, and put the light bulb sockets into their corresponding holes.
    • Twist each socket clockwise to lock them into place.
  5. 2008 Honda Pilot Tail Light Assembly Replacement: étape 5, image 1 de 3 2008 Honda Pilot Tail Light Assembly Replacement: étape 5, image 2 de 3 2008 Honda Pilot Tail Light Assembly Replacement: étape 5, image 3 de 3
    • Line the clips on the back of assembly up with their holes, and push the assembly into place.
    • Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
  6. 2008 Honda Pilot Tail Light Assembly Replacement: étape 6, image 1 de 1
    • Congratulations! You have installed a new tail light assembly on your vehicle!
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
John Forsyth
Membre depuis le 11/12/20
163 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 557
