Aller au contenu principal
2008 Toyota Prius Cabin Filter Replacement
Ce dont vous avez besoin
  1. 2008 Toyota Prius Cabin Filter Replacement, Cabin filter: étape 1, image 1 de 2 2008 Toyota Prius Cabin Filter Replacement, Cabin filter: étape 1, image 2 de 2
    • Make sure your glove compartment is empty.
  2. 2008 Toyota Prius Cabin Filter Replacement: étape 2, image 1 de 1
    • Remove your glove compartment by pushing in both sides of the frame of the compartment.
  3. 2008 Toyota Prius Cabin Filter Replacement: étape 3, image 1 de 1
    • Disconnect the hydraulic strut.
  4. 2008 Toyota Prius Cabin Filter Replacement: étape 4, image 1 de 2 2008 Toyota Prius Cabin Filter Replacement: étape 4, image 2 de 2
    • Once the hydraulic press is disconnected, you can pull it straight up, and the glove box will come out.
    • This will expose the cabin filter.
  5. 2008 Toyota Prius Cabin Filter Replacement: étape 5, image 1 de 1
    • Push both sides of the cabin filter together, and pull it straight out.
  6. 2008 Toyota Prius Cabin Filter Replacement: étape 6, image 1 de 1
    • Remove the filter from the filter holder. Then place your new filter in the filter holder.
Hopefully, this guide provided a transparent, precise set of instructions to help you replace your cabin filter; once the cabin filter is replaced to assemble the glovebox back together, follow these instructions in reverse order.
Alex Hernandez
Membre depuis le 04/12/23
157 Réputation
1 tutoriel rédigé
Équipe
Cal State LA, Spring 2024 Members Only Membre de l'équipe Cal State LA, Spring 2024 Members Only
Community
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 65
Total : 613
