Aller au contenu principal
2009-2014 Nissan Maxima CVT Fluid Change
Ce dont vous avez besoin
    • Drive the car prior to performing the CVT fluid change. The fluid should be warm when it is changed.
    • Park the car on a flat surface. While the car is running, keep your foot on the brakes and move the gear shift through all of gears: P, R, N, D1, D2, D3.
    • Put the car in Park and turn the car off.
    • Remove the transmission fluid dipstick.
    • Using a flathead screwdriver, push in the black plastic tab of the dipstick and pull it out.
    • Using a clean rag, wipe the fluid off and then reinsert it. However, insert it backwards so that it doesn't lock again.
    • Pull the dipstick out again and verify that the fluid mark is at the second notch at the bottom of the dipstick.
    • Keep the dipstick out of the drain hole.
    • Move the drain pan underneath the transmission drain pan.
    • Approximately five quarts of CVT fluid will be drained.
    • Use a 00mm socket to remove the drain bolt.
    • TIP: Use the socket to loosen the bolt and then use your fingers to finish removing the bolt. This will help prevent the fluid from leaking onto the socket wrench.
    • Leave the fluid drain for approximately 10-15 minutes.
    • Insert a new crush washer onto the drain bolt.
    • Insert the bolt into the transmission and tighten it with you fingers.
    • Use a torque wrench to tighten the bolt to xx ft/lbs.
    • Refill the transmission with CVT fluid. The car typically takes xx quarts of CVT fluid.
    • Insert three quarts of fluid.
    • Insert the dipstick and check the fluid level.
    • Continue to add small amounts of fluid until the dipstick shows that the fluid reaches the second mark from the bottom.
    • Reinsert and lock the dipstick.
    • Take the car for a drive. Don't drive too aggressively.
3 autres ont terminé cette réparation.
boarderx
Membre depuis le 05/30/14
173 Réputation
1 tutoriel rédigé
2 commentaires
Please remove the flag “in progress guide“ - as people will worry to follow this. You can do this by going to the “Edit page“ , scroll down to “Flags“ and you will see “in progress guide“; then hover over the right-upper corner of the “in progress guide” flag, You will see a x-delete button, click it.
Kind-hearted, spirited Man - Réponse
Why does it say I'll need clear plastic tubing then not mention the reason why at all!! So aggravated.
Kayla2023 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 52
30 derniers jours : 259
Total : 23,149
