Aller au contenu principal
2009-2013 Mazda 3 Air Filter Replacement
Ce dont vous avez besoin
  1. 2009-2013 Mazda 3 Air Filter Replacement, Air Filter: étape 1, image 1 de 1
    • Correctly identify the air filter for a 2009-2013 Mazda 3.
    • Go to your local car repair shop for help when buying the air filter.
  2. 2009-2013 Mazda 3 Air Filter Replacement: étape 2, image 1 de 1
    • Identify where the level is to pop the car hod.
  3. 2009-2013 Mazda 3 Air Filter Replacement: étape 3, image 1 de 1
    • After opening the hood, locate the air filter container.
    • It is located on the south side of the battery.
  4. 2009-2013 Mazda 3 Air Filter Replacement: étape 4, image 1 de 1
    • Identify where the metal clips are on the side of the air filter container.
    • Unlatch both metal clips on the air filter container to open.
  5. 2009-2013 Mazda 3 Air Filter Replacement: étape 5, image 1 de 1
    • When the air filter container is open, remove old filter.
    • When the old filter is removed, wipe out container with a wet paper towel.
    • Filter is in there tight, make sure to use a decent amount of force when pulling out.
  6. 2009-2013 Mazda 3 Air Filter Replacement: étape 6, image 1 de 1
    • Replace new filter.
    • It is a tight squeeze, so make sure the filter is properly fit into the container.
  7. 2009-2013 Mazda 3 Air Filter Replacement: étape 7, image 1 de 1
    • After you have replaced the new filter, close container and latch both metal hooks to close the container.
You have successfully changed an air filter in any 2009-2013 Mazda 3 model.
3 autres ont terminé cette réparation.
Lana Sween
Membre depuis le 01/29/18
276 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 22
30 derniers jours : 72
Total : 2,099
