Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2009-2012 Honda Fit Blower Motor and Blower Motor Control Module Replacement Replacement
Ce dont vous avez besoin
  1. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement, Blower Motor and Blower Motor Control Module Replacement: étape 1, image 1 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement, Blower Motor and Blower Motor Control Module Replacement: étape 1, image 2 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement, Blower Motor and Blower Motor Control Module Replacement: étape 1, image 3 de 3
    • Never work on car electronics when the car is running. Disconnect the battery before beginning.
    • Secure the car with the emergency break.
    • Open the glove box.
    • Push the sides to release the glove box.
    Demander à FixBot
    Ajouter un commentaire
  2. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 2, image 1 de 2 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 2, image 2 de 2
    • Unscrew the top screw on the resistor module with a long Phillips screwdriver.
    Demander à FixBot
  3. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 3, image 1 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 3, image 2 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 3, image 3 de 3
    • Find the edges of the bottom cover and pull down to release the two clips.
    • Set bottom cover aside until replacement is completed.
    Demander à FixBot
  4. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 4, image 1 de 2 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 4, image 2 de 2
    • Unscrew the bottom screw with the stubby Philips screwdriver.
    Demander à FixBot
  5. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 5, image 1 de 2 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 5, image 2 de 2
    • Pull the module out of its slot.
    • Push the tab and pull to release the module.
    • Follow these steps in reverse to replace the module.
    • If you are just replacing the control module, refer to step 11 to replace the bottom cover.
    Demander à FixBot
  6. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 6, image 1 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 6, image 2 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 6, image 3 de 3
    • Use a T20 Torx screwdriver to release the screws securing the blower motor.
    Demander à FixBot
  7. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 7, image 1 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 7, image 2 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 7, image 3 de 3
    • Slide the motor out of the slot.
    • The motor is heavy, so take care handling it.
    Demander à FixBot
  8. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 8, image 1 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 8, image 2 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 8, image 3 de 3
    • Squeeze the clip to release the wire.
    Demander à FixBot
  9. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 9, image 1 de 2 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 9, image 2 de 2
    • Attach the clip to the plug.
    • Orient the rectangular point to face the front passenger wheel.
    • Slide the motor into the circular slot so it fits snugly.
    Demander à FixBot
  10. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 10, image 1 de 1
    • Replace the three T20 Torx screws.
    Demander à FixBot
  11. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 11, image 1 de 2 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 11, image 2 de 2
    • Find the two hooks to anchor the cover to the back.
    • Place your hands under the two clips on the front and click the clips into place directly under the glove box.
    Demander à FixBot
  12. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 12, image 1 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 12, image 2 de 3 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: étape 12, image 3 de 3
    • Leaving a car engine on in an enclosed space can lead to carbon monoxide poisoning and/or death.
    • Reconnect the battery.
    • Turn the key to the third position to engage the accessory mode.
    • Make sure the AC button below the stereo is on to ensure the Air Conditioning is engaged.
    • Turn the Fan Control dial to each setting. Air should flow normal at each setting.
    Demander à FixBot
Ligne d'arrivée
Caleb French
Membre depuis le 09/24/25
205 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-8, Bray Fall 2025 Membre de l'équipe Austin Community College, Team 1-8, Bray Fall 2025
AUSTINCC-BRAY-F25S1G8
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 68
30 derniers jours : 287
Total : 1,357
