Aller au contenu principal
2009 Ducati Hypermotard 1100 Oil Replacement
Ce dont vous avez besoin
  1. 2009 Ducati Hypermotard 1100 Oil Replacement, Motor Oil: étape 1, image 1 de 2 2009 Ducati Hypermotard 1100 Oil Replacement, Motor Oil: étape 1, image 2 de 2
    • First, place a small bucket right below the hexagonal socket that is located under the motorcycle.
  2. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 2, image 1 de 2 2009 Ducati Hypermotard 1100 Oil Replacement: étape 2, image 2 de 2
    • Next, remove the drainage bolt with the 3/8 Allen wrench.
    • Twist the bolt clockwise until it is loose enough to twist off with your fingers.
    • Remember to be careful when removing the bolt because the oil could potentially be hot if the motorcycle was turned on before.
  3. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 3, image 1 de 2 2009 Ducati Hypermotard 1100 Oil Replacement: étape 3, image 2 de 2
    • Once the drainage bolt has been removed, place it to the side and wait for the old oil to drain out.
    • When the oil is just about done draining, tilt the motorcycle left and right to make sure all the oil is out of the engine as shown in the second image.
  4. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 4, image 1 de 3 2009 Ducati Hypermotard 1100 Oil Replacement: étape 4, image 2 de 3 2009 Ducati Hypermotard 1100 Oil Replacement: étape 4, image 3 de 3
    • After your old oil has drained completely; remove the oil cap by twisting clockwise with your hands as shown in the second image.
    • Next, insert the funnel into the engine as shown in the image.
  5. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 5, image 1 de 1
    • Pour in about 0.5 quart of oil into the funnel and let it drain out in order to wash out the old oil.
    • This step should be performed before you replace the drainage bolt.
  6. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 6, image 1 de 1
    • Clean your drainage bolt and wipe off all the excess oil before putting it back on underneath the motorcycle.
  7. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 7, image 1 de 2 2009 Ducati Hypermotard 1100 Oil Replacement: étape 7, image 2 de 2
    • Replace the drainage bolt with your hands.
    • When you cannot tighten it anymore manually; tighten it with your 3/8 Allen wrench.
  8. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 8, image 1 de 1
    • Pour in the new oil into the motorcycle.
    • This particular motorcycle only needs 3.5 quarts of 10W-40 motor oil (about 3 and half quarts bottles). Do not go over, or under the required amount or it can cause problems with your engine.
  9. 2009 Ducati Hypermotard 1100 Oil Replacement: étape 9, image 1 de 1
    • Screw the oil cap back on tight using your hands.
2 autres ont terminé cette réparation.
Oscar Baron
Membre depuis le 10/11/20
228 Réputation
1 tutoriel rédigé
Un commentaire
Finally it's fixed
Nicoletta - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 24
30 derniers jours : 80
Total : 2,309
