Aller au contenu principal
2009 Honda Civic Window Regulator Replacement
Ce dont vous avez besoin
  1. 2009 Honda Civic Window Regulator Replacement, Window Regulator: étape 1, image 1 de 3 2009 Honda Civic Window Regulator Replacement, Window Regulator: étape 1, image 2 de 3 2009 Honda Civic Window Regulator Replacement, Window Regulator: étape 1, image 3 de 3
    • Park the vehicle on a level surface and turn off the ignition.
  2. 2009 Honda Civic Window Regulator Replacement: étape 2, image 1 de 3 2009 Honda Civic Window Regulator Replacement: étape 2, image 2 de 3 2009 Honda Civic Window Regulator Replacement: étape 2, image 3 de 3
    • Remove the Phillips screw located behind the door handle.
  3. 2009 Honda Civic Window Regulator Replacement: étape 3, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 3, image 2 de 2
    • Place a prying tool in the small crevice at the centre of the window controller and pry upwards.
  4. 2009 Honda Civic Window Regulator Replacement: étape 4, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 4, image 2 de 2
    • Disconnect the electrical connectors attached to the panel by pressing onto the tab.
  5. 2009 Honda Civic Window Regulator Replacement: étape 5, image 1 de 3 2009 Honda Civic Window Regulator Replacement: étape 5, image 2 de 3 2009 Honda Civic Window Regulator Replacement: étape 5, image 3 de 3
    • Use a prying tool to pry off the door panel.
  6. 2009 Honda Civic Window Regulator Replacement: étape 6, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 6, image 2 de 2
    • Push downwards on the holder and pull the wire towards yourself.
  7. 2009 Honda Civic Window Regulator Replacement: étape 7, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 7, image 2 de 2
    • Use a prying tool to remove the two black plugs on the left-hand side and right-hand side of the plastic liner.
  8. 2009 Honda Civic Window Regulator Replacement: étape 8, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 8, image 2 de 2
    • Remove the connector by pushing onto the tab using a prying tool.
  9. 2009 Honda Civic Window Regulator Replacement: étape 9, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 9, image 2 de 2
    • Gently remove the plastic liner.
  10. 2009 Honda Civic Window Regulator Replacement: étape 10, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 10, image 2 de 2
    • Use a wrench to remove the two bolts located at the left-hand side and right-hand side.
  11. 2009 Honda Civic Window Regulator Replacement: étape 11, image 1 de 3 2009 Honda Civic Window Regulator Replacement: étape 11, image 2 de 3 2009 Honda Civic Window Regulator Replacement: étape 11, image 3 de 3
    • Use the wrench to unscrew the first bolt located at the top of the door in a counterclockwise motion.
    • Use the wrench to unscrew the second bolt located at the bottom of the door in a counterclockwise motion.
  12. 2009 Honda Civic Window Regulator Replacement: étape 12, image 1 de 2 2009 Honda Civic Window Regulator Replacement: étape 12, image 2 de 2
    • After removing all four bolts, use your hands to remove the window regulator.
5 autres ont terminé cette réparation.
Usman Khan
Membre depuis le 01/18/23
478 Réputation
2 tutoriels rédigés
Équipe
York University, Team 1-13, O'Regan Winter 2024 Membre de l'équipe York University, Team 1-13, O'Regan Winter 2024
YORK-O'REGAN-W24S1G13
1 membre
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 55
Total : 765
