Aller au contenu principal
2010-2017 Suzuki Swift Engine Air Filter Replacement
Ce dont vous avez besoin
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: étape 1, image 1 de 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: étape 1, image 2 de 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: étape 1, image 3 de 3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: étape 2, image 1 de 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: étape 2, image 2 de 2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: étape 3, image 1 de 1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: étape 4, image 1 de 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: étape 4, image 2 de 2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Ligne d'arrivée
knipwim
Membre depuis le 09/01/18
8 527 Réputation
30 tutoriels rédigés
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 36
30 derniers jours : 138
Total : 6,346
