Aller au contenu principal
2010-2017 Suzuki Swift Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: étape 1, image 1 de 3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: étape 1, image 2 de 3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: étape 1, image 3 de 3
    • Unscrew the two visible bolts.
    • After unscrewing the bolts, the other side of the light is still fastened by two clickable plugs.
    • Using the panel removal tool, pry behind each corner and unclick each plug.
  2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, access backside of the light: étape 2, image 1 de 1
    • Remove the light from the frame and place it on the tailgate.
    • You might need to remove some of the cabling from cable guides.
    • You can also better see the plugs that held the light in place.
  3. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, remove the fitting: étape 3, image 1 de 1
    • Unscrew the fitting about 45 degrees and lift it from the casing.
  4. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: étape 4, image 1 de 2 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: étape 4, image 2 de 2
    • Remove the bulb by turning it about 45 degrees.
    • And do the reverse with the new bulb, push and turn.
    • The bulb has 2 guide pins assuring a correct install.
    • The fitting has 2 corresponding receivers.
  5. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, insert fitting: étape 5, image 1 de 1
    • Insert the fitting by matching up the fitting guides with their openings on the casing and turn it 45 degrees clockwise.
  6. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, put the light back: étape 6, image 1 de 1
    • Tuck back any cables you loosened, and place the light back on the car frame.
    • Make sure the replaced light actually works.
    • Push the light plugs back in.
    • Put the 2 screws back in.
    • You are done.
Ligne d'arrivée
5 autres ont terminé cette réparation.
knipwim
Membre depuis le 09/01/18
8 527 Réputation
30 tutoriels rédigés
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 118
30 derniers jours : 458
Total : 35,344
