Aller au contenu principal
2010 Jeep Liberty Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: étape 1, image 1 de 1
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: étape 2, image 1 de 3 2010 Jeep Liberty Headlight Bulb Replacement: étape 2, image 2 de 3 2010 Jeep Liberty Headlight Bulb Replacement: étape 2, image 3 de 3
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: étape 3, image 1 de 3 2010 Jeep Liberty Headlight Bulb Replacement: étape 3, image 2 de 3 2010 Jeep Liberty Headlight Bulb Replacement: étape 3, image 3 de 3
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: étape 4, image 1 de 1
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Congratulations! You have a shiny new headlight.
8 autres ont terminé cette réparation.
Ryan Griffin
Membre depuis le 01/19/16
245 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 6-1, Walwema Winter 2016 Membre de l'équipe Oakland University, Team 6-1, Walwema Winter 2016
OAK-WALWEMA-W16S6G1
10 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 56
Total : 9,064
