Aller au contenu principal
2010 Toyota Corolla Headlight Replacement
Ce dont vous avez besoin
  1. 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: étape 1, image 1 de 3 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: étape 1, image 2 de 3 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: étape 1, image 3 de 3
    • Find the handle to open the Bonnet. It will be located at the bottom left-hand side of the driver's seat.
    • Pull the handle towards yourself and you will see the bonnet pop up a small bit.
  2. 2010 Toyota Corolla Headlight Replacement: étape 2, image 1 de 3 2010 Toyota Corolla Headlight Replacement: étape 2, image 2 de 3 2010 Toyota Corolla Headlight Replacement: étape 2, image 3 de 3
    • Move the handle to the left in order to release the hood completely.
    • Locate the black stick and insert it in the bonnet hole.
  3. 2010 Toyota Corolla Headlight Replacement: étape 3, image 1 de 3 2010 Toyota Corolla Headlight Replacement: étape 3, image 2 de 3 2010 Toyota Corolla Headlight Replacement: étape 3, image 3 de 3
    • On the left, upper side of the hood, you can locate the bulb
    • Twist it halfway counter-clockwise and pull it out.
  4. 2010 Toyota Corolla Headlight Replacement: étape 4, image 1 de 3 2010 Toyota Corolla Headlight Replacement: étape 4, image 2 de 3 2010 Toyota Corolla Headlight Replacement: étape 4, image 3 de 3
    • Push the hook down to detach the bulb from the wire.
  5. 2010 Toyota Corolla Headlight Replacement: étape 5, image 1 de 3 2010 Toyota Corolla Headlight Replacement: étape 5, image 2 de 3 2010 Toyota Corolla Headlight Replacement: étape 5, image 3 de 3
    • Replace it with a new bulb and turn it clockwise to have it fixed permanently.
    • If the bulb is not turned clockwise, the bulb will come off and become loose again.
  6. 2010 Toyota Corolla Headlight Replacement: étape 6, image 1 de 3 2010 Toyota Corolla Headlight Replacement: étape 6, image 2 de 3 2010 Toyota Corolla Headlight Replacement: étape 6, image 3 de 3
    • Turn on the lights to make sure both headlights are working :)
3 autres ont terminé cette réparation.
Shahbaz Khan
Membre depuis le 01/19/22
193 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-12, O'Regan Winter 2022 Membre de l'équipe York University, Team 2-12, O'Regan Winter 2022
YORK-O'REGAN-W22S2G12
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 92
Total : 2,579
