Aller au contenu principal
2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement
Ce dont vous avez besoin
  1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: étape 1, image 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: étape 1, image 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: étape 1, image 3 de 3
    • Make sure the car is off before you start your replacement. However, You don't have to disconnect the car battery.
    • Open the trunk first.
    • Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
  2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 2, image 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 2, image 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 2, image 3 de 3
    • Using both hands, carefully pull the brake & tail light off.
  3. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 3, image 1 de 1
    • Here is the tail light assembly.
    • The left one is for the brake light.
    • The right one is for the back-up light.
  4. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 4, image 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 4, image 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 4, image 3 de 3
    • Twist and turn the backup light to the right. And then pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the light bulb easily.
  5. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 5, image 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 5, image 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 5, image 3 de 3
    • Twist and turn the brake light to the right and pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the bulb easily.
  6. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 6, image 1 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 6, image 2 de 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: étape 6, image 3 de 3
    • Replace the light bulbs.
    • Check that the light bulbs work first before replacing 10 mm screws.
2 autres ont terminé cette réparation.
Adrian Ng
Membre depuis le 09/18/21
196 Réputation
1 tutoriel rédigé
Équipe
York University, Team E-20, Melo-Thaiss Fall 2021 Membre de l'équipe York University, Team E-20, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG20
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 34
30 derniers jours : 105
Total : 4,253
