Aller au contenu principal
2011-2013 Scion tC Car Battery Replacement
Ce dont vous avez besoin
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: étape 1, image 1 de 1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: étape 2, image 1 de 1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: étape 3, image 1 de 1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: étape 4, image 1 de 2 2011-2013 Scion tC Car Battery Replacement: étape 4, image 2 de 2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: étape 5, image 1 de 2 2011-2013 Scion tC Car Battery Replacement: étape 5, image 2 de 2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Travis Michael
Membre depuis le 05/08/15
140 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-2, Regan Spring 2015 Membre de l'équipe Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 32
Total : 10,800
