Aller au contenu principal
2011 Scion Tc Blower Motor Replacement
Ce dont vous avez besoin
  1. 2011 Scion Tc Blower Motor Replacement, Blower Motor: étape 1, image 1 de 1
    • Locate your blower motor. Your blower motor should be below the glovebox.
  2. 2011 Scion Tc Blower Motor Replacement: étape 2, image 1 de 1
    • Remove the three 2 mm screws that secure the blower motor.
  3. 2011 Scion Tc Blower Motor Replacement: étape 3, image 1 de 1
    • Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
  4. 2011 Scion Tc Blower Motor Replacement: étape 4, image 1 de 2 2011 Scion Tc Blower Motor Replacement: étape 4, image 2 de 2
    • Disconnect the sensor that is connect to the blower motor.
    • The sensor should have a click and carefully remove it upwards.
  5. 2011 Scion Tc Blower Motor Replacement: étape 5, image 1 de 2 2011 Scion Tc Blower Motor Replacement: étape 5, image 2 de 2
    • Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
  6. 2011 Scion Tc Blower Motor Replacement: étape 6, image 1 de 1
    • Tighten the two 1 mm screws to the wiring harness.
  7. 2011 Scion Tc Blower Motor Replacement: étape 7, image 1 de 1
    • Congratulations, you have successfully replaced your blower motor!
    • Once all the screws are tightened, just make sure to turn on your air to see if your blower motor works!
Jose Ruvalcaba
Membre depuis le 05/04/22
145 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 13-13, Harris Spring 2022 Membre de l'équipe CSU Los Angeles, Team 13-13, Harris Spring 2022
CSULA-HARRIS-S22S13G13
1 membre
1 tutoriel rédigé
Un commentaire
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
Christopher Sean Harris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 1,146
