Aller au contenu principal
2011 Toyota Sienna Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: étape 1, image 1 de 3 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: étape 1, image 2 de 3 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: étape 1, image 3 de 3
    • Pull out the hood release latch located towards the lower left of the steering wheel.
  2. 2011 Toyota Sienna Headlight Bulb Replacement: étape 2, image 1 de 3 2011 Toyota Sienna Headlight Bulb Replacement: étape 2, image 2 de 3 2011 Toyota Sienna Headlight Bulb Replacement: étape 2, image 3 de 3
    • Hold up the hood safety latch with one hand and lift the hood of the car with the other hand.
    • Pull the hood all the way up to ensure it engages and stays up.
  3. 2011 Toyota Sienna Headlight Bulb Replacement: étape 3, image 1 de 2 2011 Toyota Sienna Headlight Bulb Replacement: étape 3, image 2 de 2
    • Locate the headlight bulb housings on each side if the hood.
    • It's advisable to replace both headlights even if only one is burned out. The other light is likely to go out soon, and replacing both now can help avoid additional repairs.
  4. 2011 Toyota Sienna Headlight Bulb Replacement: étape 4, image 1 de 3 2011 Toyota Sienna Headlight Bulb Replacement: étape 4, image 2 de 3 2011 Toyota Sienna Headlight Bulb Replacement: étape 4, image 3 de 3
    • Push the button on the electrical connector until you hear a click.
    • Pull down to remove the electrical connector.
  5. 2011 Toyota Sienna Headlight Bulb Replacement: étape 5, image 1 de 2 2011 Toyota Sienna Headlight Bulb Replacement: étape 5, image 2 de 2
    • Twist the bulb counter clockwise.
  6. 2011 Toyota Sienna Headlight Bulb Replacement: étape 6, image 1 de 1
    • Pull out the bulb.
    • Insert your new light bulb.
    • If you are not wearing gloves, avoid touching the glass part of the bulb since the oils from your skin will damage the bulb.
Madeleine Falcon
Membre depuis le 09/07/23
183 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-11, O'Regan Fall 2023 Membre de l'équipe York University, Team 1-11, O'Regan Fall 2023
YORK-O'REGAN-F23S1G11
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 29
Total : 243
