Introduction
Use this guide to correctly replace the headlight bulbs on a 2011 Volkswagen Eos.
Before using this guide be sure to have nylon gloves on to prevent the oils on your hand from transferring to the new bulbs. The oils will heat faster than the glass, causing the glass to shatter once the bulb is turned on.
Ce dont vous avez besoin
With the completion of the guide, your headlight LED should be working.
