Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2012-2018 Ford Focus Side Marker Light Replacement
Ce dont vous avez besoin
  1. 2012-2018 Ford Focus Side Marker Light Replacement, Side Marker Light: étape 1, image 1 de 3 2012-2018 Ford Focus Side Marker Light Replacement, Side Marker Light: étape 1, image 2 de 3 2012-2018 Ford Focus Side Marker Light Replacement, Side Marker Light: étape 1, image 3 de 3
    • Release the hood lock found in the driver-side foot-well.
    • Find the latch under the center of the hood.
    • Depress the latch to release the hood.
    • Aline the hood strut into the designated hole to keep the hood open while working.
  2. 2012-2018 Ford Focus Side Marker Light Replacement: étape 2, image 1 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 2, image 2 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 2, image 3 de 3
    • Remove the screws connected to the headlamp using the Torx T30 socket wrench OR 10 mm flat head screwdriver.
  3. 2012-2018 Ford Focus Side Marker Light Replacement: étape 3, image 1 de 2 2012-2018 Ford Focus Side Marker Light Replacement: étape 3, image 2 de 2
    • Pull the headlamp carefully upwards towards the hood until you hear a click.
  4. 2012-2018 Ford Focus Side Marker Light Replacement: étape 4, image 1 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 4, image 2 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 4, image 3 de 3
    • Disconnect the headlamp
    • Please be careful when disconnecting the headlamp because it is fragile
  5. 2012-2018 Ford Focus Side Marker Light Replacement: étape 5, image 1 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 5, image 2 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 5, image 3 de 3
    • Twist the bulb cover counterclockwise.
    • Be careful when removing the bulb cover because it is fragile.
  6. 2012-2018 Ford Focus Side Marker Light Replacement: étape 6, image 1 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 6, image 2 de 3 2012-2018 Ford Focus Side Marker Light Replacement: étape 6, image 3 de 3
    • Pull on the bulb cover to take out the bulb holder.
  7. 2012-2018 Ford Focus Side Marker Light Replacement: étape 7, image 1 de 1
    • Pull the bulb out of the bulb holder.
    • These bulb are fine to throw away with your regular trash.
  8. 2012-2018 Ford Focus Side Marker Light Replacement: étape 8, image 1 de 2 2012-2018 Ford Focus Side Marker Light Replacement: étape 8, image 2 de 2
    • Press the new bulb into the bulb holder.
    • Do not touch the bulb with your bare hands. The oil from your hands can cause the bulb to shatter as it heats up. If you do touch the bulb, be sure to wipe the bulb clean with an alcohol wipe.
Austyne Chetwood
Membre depuis le 10/06/22
184 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 51
30 derniers jours : 225
Total : 8,259
