Aller au contenu principal
2012-2016 Scion FR-S Oil and Oil Filter Replacement
Ce dont vous avez besoin
  1. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Starting the Replacement: étape 1, image 1 de 1
    • Place the portable vehicle ramps in front of either wheel and slowly pull the vehicle up onto them.
    • Put the vehicle in park and engage the parking brake.
  2. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Locating the Oil Filter: étape 2, image 1 de 2 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Locating the Oil Filter: étape 2, image 2 de 2
    • Open the hood of the car and locate the oil filter.
  3. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Removing the Oil Filter: étape 3, image 1 de 2 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Removing the Oil Filter: étape 3, image 2 de 2
    • Remove the oil filter by turning it counterclockwise.
  4. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Locating the Oil Drain Plug: étape 4, image 1 de 2 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Locating the Oil Drain Plug: étape 4, image 2 de 2
    • Lie down under the front of the car and locate the oil drain plug in the opening on the skid plate.
  5. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Removing the Oil Drain Plug and Draining the Oil: étape 5, image 1 de 2 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Removing the Oil Drain Plug and Draining the Oil: étape 5, image 2 de 2
    • Place the oil pan below the drain plug.
    • The oil will be extremely hot if the vehicle has recently been running.
    • Remove the oil drain plug with the 14 mm socket wrench and let the oil drain into the drain pan.
  6. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Reattaching the Oil Drain Plug: étape 6, image 1 de 3 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Reattaching the Oil Drain Plug: étape 6, image 2 de 3 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Reattaching the Oil Drain Plug: étape 6, image 3 de 3
    • Allow the oil to drain from the vehicle.
    • 5 - 10 minutes will be needed for the oil to drain. This can be monitored by watching the oil drain from the location where the oil filter was removed.
    • Once there is no more oil pouring out, reattach the oil drain plug with the 14 mm socket wrench until it is tight.
  7. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Reattaching the Oil Filter: étape 7, image 1 de 2 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Reattaching the Oil Filter: étape 7, image 2 de 2
    • Screw the new oil filter in a clockwise rotation onto the same area where the old one was removed until it is tight.
  8. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Filling the Vehicle with Oil: étape 8, image 1 de 3 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Filling the Vehicle with Oil: étape 8, image 2 de 3 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Filling the Vehicle with Oil: étape 8, image 3 de 3
    • Locate the oil fill cap that is beside the new filter and take it off. Then pour the oil in using the funnel.
    • Only pour in 5.8 quarts of oil. Pouring in too much oil may cause damage to the engine.
    • Pour slowly so that the oil does not spill out of the funnel.
    • Remove the funnel and firmly reattach the oil fill cap.
  9. 2012-2016 Scion FR-S Oil and Oil Filter Replacement, Checking the Oil Level: étape 9, image 1 de 1
    • Slowly roll the vehicle off of the portable vehicle ramps.
    • Check the dipstick to make sure there is enough oil. The level indicated should be in-between the two metal dimples on the end of the dipstick.
    • If the vehicle is not on level ground, the dipstick may not show an accurate reading.
    • Safely dispose of the remaining oil and the old oil filter.
Congratulations on changing the oil on your 2012-2016 Scion FR-S!
Christopher Kidwell
Membre depuis le 04/22/21
209 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 73
Total : 1,181
