Aller au contenu principal
2012-2015 Honda Civic Air Filter Replacement
  1. 2012-2015 Honda Civic Air Filter Replacement, Air Filter: étape 1, image 1 de 3 2012-2015 Honda Civic Air Filter Replacement, Air Filter: étape 1, image 2 de 3 2012-2015 Honda Civic Air Filter Replacement, Air Filter: étape 1, image 3 de 3
    • Locate the "hood open" lever on the driver's side of the inside of the car, below the dashboard. Pull lever toward you. You will hear a "click." Go to the front of the car. The hood should be "popped" slightly. Reach under the hood, find a lever, and move the lever to the left. This will completely release the hood latch.
  2. 2012-2015 Honda Civic Air Filter Replacement: étape 2, image 1 de 3 2012-2015 Honda Civic Air Filter Replacement: étape 2, image 2 de 3 2012-2015 Honda Civic Air Filter Replacement: étape 2, image 3 de 3
    • Find the anchor to hold up the hood of your car. This anchor should be laying along the ledge in front of the radiator. Lift the anchor and insert the end into the hole on the lower side of the hood.
  3. 2012-2015 Honda Civic Air Filter Replacement: étape 3, image 1 de 2 2012-2015 Honda Civic Air Filter Replacement: étape 3, image 2 de 2
    • As you are facing the Civic, the air filter will be inside the black plastic box to the right of the valve cover.
  4. 2012-2015 Honda Civic Air Filter Replacement: étape 4, image 1 de 3 2012-2015 Honda Civic Air Filter Replacement: étape 4, image 2 de 3 2012-2015 Honda Civic Air Filter Replacement: étape 4, image 3 de 3
    • There will be four clips on the air filter box - two on the front, one on the right and one on the right back. Release the clips from the box by pushing them away from the box.
  5. 2012-2015 Honda Civic Air Filter Replacement: étape 5, image 1 de 3 2012-2015 Honda Civic Air Filter Replacement: étape 5, image 2 de 3 2012-2015 Honda Civic Air Filter Replacement: étape 5, image 3 de 3
    • Gently lift the cover of the box from the lower part of the box. Remove the old air filter from the box and set it aside. Place the new air filter in the box. Replace the cover and place the four clips back on the box.
6 autres ont terminé cette réparation.
rayyan
Membre depuis le 03/27/15
221 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 5-7, Williams Spring 2015 Membre de l'équipe Baylor, Team 5-7, Williams Spring 2015
BU-WILLIAMS-S15S5G7
4 membres
9 tutoriels rédigés
Un commentaire
Haha this is not moderately or even remotely hard to do, I made a 1 minute diy video that shows how simple it is.
https://youtu.be/Hw_TppaPzp8
lukedavidjohnson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 50
30 derniers jours : 178
Total : 15,452
