Aller au contenu principal
2012 Chevy Equinox Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 3 de 3
    • Open the trunk of your car.
  2. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 2, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 2, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 2, image 3 de 3
    • Remove the two plastic caps by placing a spudger in the bottom opening and gently prying upward.
  3. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 3, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 3, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 3, image 3 de 3
    • Remove the two 6 mm Phillips #2 screws located underneath each of the plastic caps by twisting counterclockwise.
  4. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 4, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 4, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 4, image 3 de 3
    • Hold the latch down firmly and pull the tail light cover off the vehicle.
    • You may have to apply a back and forth force to remove the cover.
  5. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 5, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 5, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 5, image 3 de 3
    • Remove the light bulb socket from the vehicle by gently twisting and pulling it out of the tail light cover.
  6. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 6, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 6, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 6, image 3 de 3
    • Twist the light bulb counterclockwise and pull to remove it from the socket.
  7. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 7, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 7, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 7, image 3 de 3
    • Insert the new light bulb by gently pushing the light bulb into the socket and twisting clockwise.
    • When reassembling, make sure to align the tail light cover up to the back of the vehicle before pushing the cover back on.
Kelly Dixon
Membre depuis le 10/13/20
145 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team S9-G2, Cowan Fall 2020 Membre de l'équipe Texas Tech, Team S9-G2, Cowan Fall 2020
TTU-COWAN-F20S9G2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 38
Total : 1,937
