Aller au contenu principal
2013 Chevrolet Sonic Oil Filter Replacement
Ce dont vous avez besoin
  1. 2013 Chevrolet Sonic Oil Filter Replacement, Oil Filter: étape 1, image 1 de 2 2013 Chevrolet Sonic Oil Filter Replacement, Oil Filter: étape 1, image 2 de 2
    • Pop the hood of the car and prop open with a prop rod.
    • Automotive ramps are not needed and gloves are recommended.
    • Locate the oil filter cap.
    • Place a bucket or drain pan underneath the car, lined up with the location of the filter, to catch excess oil in.
  2. 2013 Chevrolet Sonic Oil Filter Replacement: étape 2, image 1 de 3 2013 Chevrolet Sonic Oil Filter Replacement: étape 2, image 2 de 3 2013 Chevrolet Sonic Oil Filter Replacement: étape 2, image 3 de 3
    • Using a ratchet and 15/16 mm socket, remove the cap for the oil filter.
  3. 2013 Chevrolet Sonic Oil Filter Replacement: étape 3, image 1 de 2 2013 Chevrolet Sonic Oil Filter Replacement: étape 3, image 2 de 2
    • Carefully remove the cap, letting excess oil drip into the bucket below.
    • The internal rod should remain intact.
  4. 2013 Chevrolet Sonic Oil Filter Replacement: étape 4, image 1 de 3 2013 Chevrolet Sonic Oil Filter Replacement: étape 4, image 2 de 3 2013 Chevrolet Sonic Oil Filter Replacement: étape 4, image 3 de 3
    • Separate the old filter from the cap.
    • Spray down the cap with brake cleaner.
    • Caution: Brake cleaner is dangerous to eyes and contacts. To prevent injury, wear protective safety glasses.
  5. 2013 Chevrolet Sonic Oil Filter Replacement: étape 5, image 1 de 3 2013 Chevrolet Sonic Oil Filter Replacement: étape 5, image 2 de 3 2013 Chevrolet Sonic Oil Filter Replacement: étape 5, image 3 de 3
    • Remove the old O ring (blue plastic ring) from the cap and replace it with a new one.
    • This may not come off easily. You may need to use a screwdriver or pick to remove it.
    • Using your finger, wipe some clean oil onto the new O ring on the cap to lubricate it for easier reinstallment.
  6. 2013 Chevrolet Sonic Oil Filter Replacement: étape 6, image 1 de 1
    • Add a new filter either to the cap or directly onto the internal rod in the vehicle.
    • The filter clicks into the cap, but will just rest on the rod.
  7. 2013 Chevrolet Sonic Oil Filter Replacement: étape 7, image 1 de 1
    • Reinstall the cap and use a ratchet and socket to tighten it into place.
    • Using the brake cleaner, spray off any excess oil from around the filter.
It is recommended that this is done while changing the oil and/or once every 5000 miles.
Madison Smith
Membre depuis le 03/20/21
178 Réputation
1 tutoriel rédigé
2 commentaires
Does the internal rod have a spring in the center of it recently changed oil in 2013 sonic and pulled spring and some broken plastic parts out of center of rod you can reach me at cvn300mag@aol.com
Dan foster - Réponse
Is this the 1.4l engine or the 1.8l?
Richard Klein - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 67
30 derniers jours : 294
Total : 5,786
