Introduction
This is a step by step guide to assist you replace the halogen headlight bulb with a LED bulb on a 2013 Honda Accord. This replacement is required when the bulb is getting dim or is completely out. It is recommended that you replace both bulbs at the same time as the other bulb will probably start to dim as well.
Please make sure that the new LED headlight bulbs are compatible with the vehicle. In addition, don't touch the glass of the new bulb with your fingers as the oil from your hands can reduce the life of the bulb or cause it to shatter.
Before beginning this repair, make sure to to turn off your car and put the parking brake on.
Ce dont vous avez besoin
Pull the tab beside the driver side footwell to release the hood.
Pull the tab locking the hood upwards.
Pull the hood up to its maximum position.
