Aller au contenu principal
2013 Honda Civic Brake Light Replacement
Ce dont vous avez besoin
  1. 2013 Honda Civic Brake Light Replacement, Brake Light: étape 1, image 1 de 2 2013 Honda Civic Brake Light Replacement, Brake Light: étape 1, image 2 de 2
    • Ensure that the vehicle is shut off before engaging in the replacement.
    • Open the trunk by pulling the latch located on the floor of the driver’s side.
  2. 2013 Honda Civic Brake Light Replacement: étape 2, image 1 de 3 2013 Honda Civic Brake Light Replacement: étape 2, image 2 de 3 2013 Honda Civic Brake Light Replacement: étape 2, image 3 de 3
    • The carpet liner attached to the trunk has a total of six rivet fasteners. There are three rivet fasteners located on the edges of both the right and the left sides of the trunk.
    • Using a flathead screwdriver, remove all the rivet fasteners attached to the carpet liner.
  3. 2013 Honda Civic Brake Light Replacement: étape 3, image 1 de 2 2013 Honda Civic Brake Light Replacement: étape 3, image 2 de 2
    • Pull back the carpet liner from the walls of the trunk.
    • Locate the housing compartment for the brake light socket.
  4. 2013 Honda Civic Brake Light Replacement: étape 4, image 1 de 2 2013 Honda Civic Brake Light Replacement: étape 4, image 2 de 2
    • Remove the brake light socket from the housing compartment by turning it ¼ of a turn counterclockwise to unlock.
    • Pull the brake light socket from the housing compartment.
  5. 2013 Honda Civic Brake Light Replacement: étape 5, image 1 de 3 2013 Honda Civic Brake Light Replacement: étape 5, image 2 de 3 2013 Honda Civic Brake Light Replacement: étape 5, image 3 de 3
    • Remove the burned-out light bulb from the brake light socket.
  6. 2013 Honda Civic Brake Light Replacement: étape 6, image 1 de 2 2013 Honda Civic Brake Light Replacement: étape 6, image 2 de 2
    • Insert the new brake light bulb into the brake light socket.
  7. 2013 Honda Civic Brake Light Replacement: étape 7, image 1 de 2 2013 Honda Civic Brake Light Replacement: étape 7, image 2 de 2
    • Insert the brake light socket back into the housing compartment by turning it ¼ of a turn clockwise to lock.
Ligne d'arrivée
Abdullahi Mohamed
Membre depuis le 09/13/21
172 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-7, O'Regan Fall 2021 Membre de l'équipe York University, Team 2-7, O'Regan Fall 2021
YORK-O'REGAN-F21S2G7
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 105
30 derniers jours : 335
Total : 6,945
