Aller au contenu principal
2013 Kia Forte Wheel Replacement
Ce dont vous avez besoin
  1. 2013 Kia Forte Wheel Replacement, Wheel: étape 1, image 1 de 1
    • Open trunk. Most 2013 models do not have a trunk button on the remote. In order to open trunk, hold down unlock button.
  2. 2013 Kia Forte Wheel Replacement: étape 2, image 1 de 3 2013 Kia Forte Wheel Replacement: étape 2, image 2 de 3 2013 Kia Forte Wheel Replacement: étape 2, image 3 de 3
    • Remove the three trunk mats, shown in order.
    • The bottom, hard plastic mat serves as a surface to lay on, if need, whilst changing tire.
  3. 2013 Kia Forte Wheel Replacement: étape 3, image 1 de 1
    • Spare tire and tools needed to change tire are located under the trunk mats.
    • The jack and lug wrench are placed in a styrofoam container on top of the spare tire.
  4. 2013 Kia Forte Wheel Replacement: étape 4, image 1 de 2 2013 Kia Forte Wheel Replacement: étape 4, image 2 de 2
    • Turning counterclockwise, unscrew and remove plastic place holder in center of spare tire.
  5. 2013 Kia Forte Wheel Replacement: étape 5, image 1 de 2 2013 Kia Forte Wheel Replacement: étape 5, image 2 de 2
    • Loosen lug nuts turning counterclockwise, one turn each.
    • Do not loosen lug nuts by circling the tire. Loosen them first in the 1, 3 and 5 positions (shown in red circles; the '1' position pointing north). After loosening the 1, 3 and 5 positions, loosen 2 and 4.
    • Do not completely remove ANY lug nuts until tire is raised from ground.
  6. 2013 Kia Forte Wheel Replacement: étape 6, image 1 de 2 2013 Kia Forte Wheel Replacement: étape 6, image 2 de 2
    • Place jack under jack plate, under appropriate tire.
    • Jack plates are welded to frame with two tabs and raised dots to indicate index with jack.
  7. 2013 Kia Forte Wheel Replacement: étape 7, image 1 de 3 2013 Kia Forte Wheel Replacement: étape 7, image 2 de 3 2013 Kia Forte Wheel Replacement: étape 7, image 3 de 3
    • Insert jack hook into loop on jack.
    • Insert end of jack hook into lug wrench.
    • To raise vehicle turn the lug wrench, attached to jack hook, clockwise. Turn until tire is one inch (approximately 30mm) off ground.
  8. 2013 Kia Forte Wheel Replacement: étape 8, image 1 de 3 2013 Kia Forte Wheel Replacement: étape 8, image 2 de 3 2013 Kia Forte Wheel Replacement: étape 8, image 3 de 3
    • Once tire is elevated, remove lug nuts by hand.
    • Be aware that the tire will shift as lug nuts are removed.
    • After removing lug nuts, carefully take tire off of frame.
  9. 2013 Kia Forte Wheel Replacement: étape 9, image 1 de 2 2013 Kia Forte Wheel Replacement: étape 9, image 2 de 2
    • Place spare tire onto frame.
    • Hand tighten lug nuts (the 1, 3 and 5 positions first) until secure.
  10. 2013 Kia Forte Wheel Replacement: étape 10, image 1 de 2 2013 Kia Forte Wheel Replacement: étape 10, image 2 de 2
    • Lower vehicle, turning jack counterclockwise, until tire touches ground.
    • Tighten lug nuts (again, beginning with the 1, 3 and 5 positions) with lug wrench until secure.
  11. 2013 Kia Forte Wheel Replacement: étape 11, image 1 de 1
    • Congratulations, your tire is changed!
    • NOTE: obey the speed limitations of your spare tire. Exceeding the recommended speed is dangerous and can damage the spare.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Kaleb
Membre depuis le 03/16/15
212 Réputation
1 tutoriel rédigé
Un commentaire
Anyone have anything to share about this vehicle?
Experience, maintenance and repair logs or experiences of note?
Thanks, ive just received this car and have been told its a good one. Have no prior experience with kias though.
2.0 cyclical engine.
RxMode - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 53
Total : 8,474
