Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: étape 1, image 1 de 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: étape 1, image 2 de 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
    Demander à FixBot
  2. 2013 Lexus IS250 Front Dome Light Replacement: étape 2, image 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 2, image 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 2, image 3 de 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
    Demander à FixBot
  3. 2013 Lexus IS250 Front Dome Light Replacement: étape 3, image 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 3, image 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 3, image 3 de 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
    Demander à FixBot
  4. 2013 Lexus IS250 Front Dome Light Replacement: étape 4, image 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 4, image 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 4, image 3 de 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
    Demander à FixBot
  5. 2013 Lexus IS250 Front Dome Light Replacement: étape 5, image 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 5, image 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 5, image 3 de 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
    Demander à FixBot
  6. 2013 Lexus IS250 Front Dome Light Replacement: étape 6, image 1 de 2 2013 Lexus IS250 Front Dome Light Replacement: étape 6, image 2 de 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
    Demander à FixBot
  7. 2013 Lexus IS250 Front Dome Light Replacement: étape 7, image 1 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 7, image 2 de 3 2013 Lexus IS250 Front Dome Light Replacement: étape 7, image 3 de 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
    Demander à FixBot
  8. 2013 Lexus IS250 Front Dome Light Replacement: étape 8, image 1 de 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
    Demander à FixBot
Christian
Membre depuis le 10/23/23
157 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-3, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 5-3, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G3
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 57
Total : 839
