Aller au contenu principal
2013 Toyota Camry Rear Brake Light Bulb Replacement
Ce dont vous avez besoin
  1. 2013 Toyota Camry Rear Brake Light Bulb Replacement, Rear Brake Light Bulb Replacement: étape 1, image 1 de 1
    • Be sure that your car is completely turned off.
    • Pop the trunk open.
  2. 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 2, image 1 de 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 2, image 2 de 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 2, image 3 de 3
    • Use a spudger to pry out the two smaller fasteners inside the trunk.
    • Push on the hook fastener to remove it.
  3. 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 3, image 1 de 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 3, image 2 de 2
    • Peel back the canvas on the side where you are replacing the bulb.
    • You will begin to see the cables connected to the rear light.
  4. 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 4, image 1 de 1
    • You will see three connections; a brake light, a turn signal light, and a parking light.
    • The one we will be replacing is the brake light bulb, the biggest connection of the three.
  5. 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 5, image 1 de 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 5, image 2 de 2
    • Turn the bulb counterclockwise from the outer connection portion (the black part).
    • Pull the old light bulb from its connection.
    • This may be a bit difficult to pull apart, but not tools are required.
  6. 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 6, image 1 de 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 6, image 2 de 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 6, image 3 de 3
    • Before handling the new light bulb, wear latex gloves or something to cover your hands. Handling the bulb with bare hands will shorten the light bulb's life span.
    • Plug the new light bulb into the connection by pushing until you hear a click.
  7. 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 7, image 1 de 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 7, image 2 de 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: étape 7, image 3 de 3
    • Place the connection into its slot and turn it clockwise to ensure it stays in place.
    • Follow Steps 2 and 3 in reverse.
Ligne d'arrivée
Chris
Membre depuis le 11/14/22
170 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-40, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 2-40, Briggs Fall 2022
CSULA-BRIGGS-F22S2G40
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 47
Total : 962
