Aller au contenu principal
2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement
Ce dont vous avez besoin
  1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: étape 1, image 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: étape 1, image 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: étape 1, image 3 de 3
    • Start by pressing down on the button that opens the center arm-rest.
    • Pop each side of the silver trim using the trim removal tool or a plastic opening tool.
    • Remove the silver trim.
  2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 2, image 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 2, image 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 2, image 3 de 3
    • Remove the two 20 mm screws securing the center console with a T20 Torx screwdriver.
  3. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 3, image 1 de 2 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 3, image 2 de 2
    • Make sure there aren't any loose articles in the center storage compartment.
    • Lift the end of the center-console and flip it to reveal the undercarriage of the center-dial touchpad and its wirings.
  4. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 4, image 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 4, image 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 4, image 3 de 3
    • Press your thumb on the safety tab to remove each blue connection.
  5. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 5, image 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 5, image 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 5, image 3 de 3
    • Press down on the center of the white connection in the middle and slide the safety latch to the left to pull out the main white connection.
  6. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 6, image 1 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 6, image 2 de 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: étape 6, image 3 de 3
    • Remove the two 15 mm T15 Torx screws holding the center-dial touchpad.
    • Firmly press the center-dial touchpad out to remove the unit.
4 autres ont terminé cette réparation.
Amin Fadhil
Membre depuis le 09/19/20
243 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G87, Woodhouse Fall 2020 Membre de l'équipe York University, Team S1-G87, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G87
1 membre
1 tutoriel rédigé
Un commentaire
This is great thanks, made an account to say thank you
Nolan Scott - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 34
30 derniers jours : 170
Total : 11,154
