Aller au contenu principal
2014-2016 Toyota Corolla Engine Air Filter Replacement
Ce dont vous avez besoin
  1. 2014-2016 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: étape 1, image 1 de 2 2014-2016 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: étape 1, image 2 de 2
    • Open the hood of your Corolla by pulling the hinge at the bottom of your dash and hold it up using the hood lift support.
    • Pull the hinge in the lower part of your driver-side dashboard. It should have an icon of a vehicle with its hood up.
    • Once you pull it, open up the hood and use the support located at the center of the engine bay to hold the hood up.
  2. 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 2, image 1 de 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 2, image 2 de 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 2, image 3 de 3
    • Find air filter box and unclip the clips on the air filter's sides.
    • Take your hand to the clips and pull them slightly. You can remove the top of the air filter box if done right.
  3. 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 3, image 1 de 2 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 3, image 2 de 2
    • Hold the air filter top up and pull out the old air filter.
    • Once old air filter is removed, get your new one and line up the square corner of the filter with the square corner of the air filter box.
    • Insert the new air filter with this orientation.
  4. 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 4, image 1 de 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 4, image 2 de 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: étape 4, image 3 de 3
    • Clip back the clips on the sides of the air filter box to close it.
    • Congratulations, you have successfully replaced the air filter in your Corolla.
Congratulations, you have replaced the air filter in your Corolla.
Romer Pena
Membre depuis le 09/20/23
136 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-10, Meigs Fall 2023 Membre de l'équipe Austin Community College, Team 1-10, Meigs Fall 2023
AUSTINCC-MEIGS-F23S1G10
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 166
Total : 616
