Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2014 Honda CTX 700NA Oil and Oil Filter Replacement
Ce dont vous avez besoin
  1. 2014 Honda CTX 700NA Oil and Oil Filter Replacement, Oil and Oil Filter: étape 1, image 1 de 2 2014 Honda CTX 700NA Oil and Oil Filter Replacement, Oil and Oil Filter: étape 1, image 2 de 2
    • Open the oil reservoir cap, located on the right side of the bike just behind the foot peg.
    Demander à FixBot
    Ajouter un commentaire
  2. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 2, image 1 de 3 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 2, image 2 de 3 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 2, image 3 de 3
    • Using a ratchet and socket, loosen the bolt.
    Demander à FixBot
  3. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 3, image 1 de 1
    • Once the bolt is removed the oil will drain out. Let all of the oil drain into the oil pan.
    • The drip should be as pictured before screwing the bolt back in.
    Demander à FixBot
  4. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 4, image 1 de 1
    • Once the bolt is tightly secured back in, unscrew the oil filter.
    • The oil filter is located on the underside of the bike but near the front wheel. If the filter is too tight, use channel lock pliers to get it off.
    Demander à FixBot
  5. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 5, image 1 de 2 2014 Honda CTX 700NA Oil and Oil Filter Replacement: étape 5, image 2 de 2
    • Once the new oil filter is installed, return to the oil reservoir mentioned in step 1. Insert a funnel and begin pouring in new oil, the type of oil required is SAE 10W-30.
    • If you change the oil filter 3.6 quarts will be needed. If you didn't replace the oil filter only 3.3 quarts will be needed.
    Demander à FixBot
4 autres ont terminé cette réparation.
Timothy Riggs
Membre depuis le 03/04/21
217 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 64
30 derniers jours : 301
Total : 8,512
