Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2014 Toyota Corolla Model L Cabin Air Filter Replacement
Ce dont vous avez besoin
    1. 2014 Toyota Corolla Model L Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 1
      • Remove all of the Items in your car's glove box.
      Demander à FixBot
      Ajouter un commentaire
    2. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 2, image 1 de 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 2, image 2 de 2
      • Pull the glove box damper apart from screw located on the right side of the glove box.
      Demander à FixBot
    3. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 3, image 1 de 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 3, image 2 de 2
      • Push the two sides of the glovebox inwards towards each other and gently bring the glovebox down all the way.
      • The glovebox will completely detach.
      Demander à FixBot
    4. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 4, image 1 de 3 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 4, image 2 de 3 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 4, image 3 de 3
      • Locate the cabin air filter which has a black cap.
      • Push the tab on the right side of the black cap and push it towards the left to remove it.
      Demander à FixBot
    5. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 5, image 1 de 1
      • Remove and replace the air filter with the arrow pointing the same direction as your last air filter which will be downwards.
      • CAUTION: Your air filter will be filled with dust, leaves, and dirt. You may want to wear a mask to not inhale these harmful items.
      Demander à FixBot
    6. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 6, image 1 de 1
      • Put the black top of the filter back into place and click it back into place.
      Demander à FixBot
    7. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 7, image 1 de 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 7, image 2 de 2
      • Attach the black hinges located on the bottom of the glovebox back into place.
      • Lift the glovebox back into its original position.
      Demander à FixBot
    8. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 8, image 1 de 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: étape 8, image 2 de 2
      • Push the glove box damper back into the screw.
      Demander à FixBot
2 autres ont terminé cette réparation.
Victor_
Membre depuis le 10/25/23
211 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-16, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 4-16, Kershman Fall 2023
CSULA-KERSHMAN-F23S4G16
1 membre
9 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 25
30 derniers jours : 143
Total : 2,954
