Aller au contenu principal
2015 Mini Cooper Key Fob Battery Replacement
Ce dont vous avez besoin
  1. 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: étape 1, image 1 de 2 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: étape 1, image 2 de 2
    • Using a plastic opening tool, create leverage in the corner of the backplate.
    • Pry open the corner and move along the seam to the middle while twisting upwards to push the cover upwards.
    • Repeat on the other side.
  2. 2015 Mini Cooper Key Fob Battery Replacement: étape 2, image 1 de 1
    • Insert a plastic opening tool in the notch on the front of the key fob and pry up the backplate in the center until it pops off.
    • If you hear cracking, make sure both the corners are detached.
  3. 2015 Mini Cooper Key Fob Battery Replacement: étape 3, image 1 de 2 2015 Mini Cooper Key Fob Battery Replacement: étape 3, image 2 de 2
    • Press the silver button on the side of the neck, and pull the key out.
    • Insert the key into the latch on the back of the battery casing, above the slot where it comes out. Pull up and out.
    • If the backing doesn't come out easily, take the key out and try again.
  4. 2015 Mini Cooper Key Fob Battery Replacement: étape 4, image 1 de 1
    • Use your finger to press down and forward on the battery. It should pop out.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 59
30 derniers jours : 145
Total : 8,525
