Aller au contenu principal
2015 Nissan Altima Mass Air Flow Sensor Replacement
Ce dont vous avez besoin
  1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: étape 1, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: étape 1, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: étape 1, image 3 de 3
    • Open the driver's side door where the hood release is located.
  2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 2, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 2, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 2, image 3 de 3
    • Connect a scanner by clicking it into the obd2 port.
  3. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 3, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 3, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 3, image 3 de 3
    • Run the code through the scanner.
  4. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 4, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 4, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 4, image 3 de 3
    • Open up the hood latch.
    • Locate front hood holder and lift it up for safety.
  5. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 5, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 5, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 5, image 3 de 3
    • Locate the battery and a positive and negative terminal.
    • The Positive terminal.
    • The Negative terminal.
    • Be careful risk of electrical shock
  6. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 6, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 6, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 6, image 3 de 3
    • Unscrew the positive terminal with a 10mm wrench by turning it counterclockwise.
  7. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 7, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 7, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 7, image 3 de 3
    • Unscrew the negative terminal with a 10mm wrench by turning it counterclockwise.
  8. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 8, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 8, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 8, image 3 de 3
    • Unplug the mass air flow sensor by pushing in the pull tabs and pulling upwards.
  9. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 9, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 9, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 9, image 3 de 3
    • Remove the screws with a Phillips #1 screwdriver by turning them counterclockwise.
  10. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 10, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 10, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 10, image 3 de 3
    • Remove the old sensor by pulling it off and replace with a new one.
  11. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 11, image 1 de 2 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 11, image 2 de 2
    • Screw back on the screws with a Phillips #1 screwdriver by turning them clockwise.
  12. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 12, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 12, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 12, image 3 de 3
    • Click the sensor in place.
    • Plug in the battery by following steps 6 and 7 in reverse order.
  13. 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 13, image 1 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 13, image 2 de 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: étape 13, image 3 de 3
    • Run the scanner again and make sure no check engine light is on and no trouble codes appear.
Ligne d'arrivée
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 110
Total : 504
