Aller au contenu principal
2016 Nissan Altima Door Courtesy Lamp Replacement
Ce dont vous avez besoin
  1. 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: étape 1, image 1 de 2 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: étape 1, image 2 de 2
    • Open the door with the faulty courtesy lamp.
    • The courtesy lamp should be located on the bottom of the door.
  2. 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 2, image 1 de 2 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 2, image 2 de 2
    • Gently pry the lamp housing away from the door using a ESD-safe pry tool.
  3. 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 3, image 1 de 1
    • Press down on the white release tab at the far left end of the lamp housing.
  4. 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 4, image 1 de 2 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 4, image 2 de 2
    • Pull back on the release tab as you press down to separate the lamp housing from the door wiring.
  5. 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 5, image 1 de 1
    • Reinsert the wire plug back into the lamp housing.
    • Gently push on the plug until you can no longer insert it further.
    • You should hear an audible click once you've inserted the plug all the way.
  6. 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 6, image 1 de 1
    • Turn on the vehicle to verify that the new light works.
    • Look at the bulb to verify that it lights up.
    • You may have to close and re-open the door in order for the light to turn on.
    • There is a chance of electric shock if the wires to your courtesy light are faulty. Avoid touching the light bulb or wires directly.
  7. 2016 Nissan Altima Door Courtesy Lamp Replacement: étape 7, image 1 de 1
    • Insert the bottom latches of the lamp into the door socket.
    • Push the top of the lamp into the socket so that the lamp housing is flush with the car door.
    • Reinserting the lamp may require more force than it appears.
If you followed all of the steps correctly your courtesy door lamp should be replaced and functional!
Jay Michalek
Membre depuis le 02/23/23
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 45
Total : 494
